Brake Pads, Wired or Not?
Old 10-17-2011 | 09:31 PM
AudimaniaA4's Avatar
Default Brake Pads, Wired or Not?
I am trying to replace my front brake pad and I am getting several different results. The recommended pads are either wired with square connection, wired with oval connection, or without a wire. Is there any way I can identify which brake pad is the right one? I inspected the caliper and could not see if the pad included a wire or not. By the way, I have a 1998 (1998.5 model) 2.8 A4 Quattro.
Thanks!
P.S.
If you don't know the answer to this question dont worry I'm sure ImTheDevil will answer it.
Old 10-17-2011 | 09:44 PM
NHolzschuh's Avatar
most assuredly, jeremy has a knack for that.
Old 10-17-2011 | 10:51 PM
Audacity's Avatar
we could go by process of elimination, my 99.5 1.8 has ovals i think,
Old 10-17-2011 | 11:41 PM
ImTheDevil's Avatar
Lol you guys crack me up. But screw it I'm thinking yours doesn't have them, since my early 99 doesn't either. If not, you can get any pads you want and cut the wires off. The wires/connectors should be visible either through the wheel or by lifting the car up (with a real jack, not that erector-set turd in the trunk), and inspecting the caliper assembly.
Old 10-18-2011 | 12:19 AM
This guy is like a freakin walking dictionary YO DA MAN!
Old 10-18-2011 | 04:00 AM
MetalMan's Avatar
Moderator
Yep it's doubtful you'll have connectors for wear sensors
Old 10-18-2011 | 09:54 AM
ImTheDevil's Avatar
Lmao there are guys on here that have forgotten more about Audis than I know but thanks, and I'll always chime in when I think I can help
jinsojoo
09-16-2021 05:49 PM
speedracr226
08-05-2009 06:07 PM
br.drums
09-11-2008 05:46 PM
Sp33d07
01-17-2006 03:29 AM
black b5
06-01-2005 10:36 PM
