BOSE speakers for$40?!
ok so i just found this http://forums.quattroworld.com/s4/msgs/53836.phtml
it says that if your car is 10 years old or older you can buy replacement BOSE speakers directly from BOSE. has anyone tried this? is it really true? hehhe
i really need a front driver side replacement speaker
You won't be able to tell without taking it the speaker out. On the front there is a round black pad (dust cap), that sometimes comes loose and needs to be re-epoxyed. If this isn't floating around in inside, then the speaker is probably blown.
Check this out:
https://www.audiforums.com/forum/sho...r+sounds+blown
That wasn't my problem and ended up buying a speaker from Shokan.
Dont buy from Shokan - its just cheaper priced crap.
Buy new speakers from Infinity - they make 2ohm speakers, which plug directly into the old system. Sounds great - no weaksauce paper cones blowing out anymore....
Unless you plan on changing all the speakers, you won't want to switch to Infinity.
