BOSE speakers for$40?!
Old 01-18-2010, 11:31 PM
Tourbo24's Avatar
Default BOSE speakers for$40?!
ok so i just found this http://forums.quattroworld.com/s4/msgs/53836.phtml
it says that if your car is 10 years old or older you can buy replacement BOSE speakers directly from BOSE. has anyone tried this? is it really true? hehhe
i really need a front driver side replacement speaker
Old 01-19-2010, 12:22 AM
jmgrande's Avatar
I had a blown speaker and order a new (fully working used on) one from Shokan, it was $77 shipped.
Do you have no sound, or does it sound blown out? Make sure the dust cap hasn't just come unglued first.
Old 01-19-2010, 12:34 AM
Tourbo24's Avatar
i have sound its very quiet and its kinda buzzing
i am a noob at speakers, what is a dust cap? lol
Old 01-19-2010, 12:44 AM
jmgrande's Avatar
Sounds like it is blown, what does it sound like when you put all the sound to that speaker?
You won't be able to tell without taking it the speaker out. On the front there is a round black pad (dust cap), that sometimes comes loose and needs to be re-epoxyed. If this isn't floating around in inside, then the speaker is probably blown.
Check this out:
https://www.audiforums.com/forum/sho...r+sounds+blown
That wasn't my problem and ended up buying a speaker from Shokan.
Old 01-19-2010, 12:53 AM
Tourbo24's Avatar
so to get to the dust cap i need to unscrew the speaker? cuz i checked last week if i had some loose connection but i never really took the whole speaker out. will probably do it tomorrow
Old 01-19-2010, 12:58 AM
jmgrande's Avatar
Yes, it can be found under the speaker grille. It would be floating around inside if this was the problem.
Old 01-19-2010, 10:28 AM
RockyMountainB5's Avatar
Dont buy from Shokan - its just cheaper priced crap.
Buy new speakers from Infinity - they make 2ohm speakers, which plug directly into the old system. Sounds great - no weaksauce paper cones blowing out anymore....
Old 01-19-2010, 10:51 AM
jmgrande's Avatar
I don't know what that means, Shokan sells OEM parts that are taken from wrecked Audis.
Unless you plan on changing all the speakers, you won't want to switch to Infinity.
Old 01-19-2010, 12:40 PM
osin34's Avatar
yea i love shokan.. for the right parts they are the best way to go..
Old 01-19-2010, 01:22 PM
Tourbo24's Avatar
I just found some guy selling the speaker for $9 or $29 for the speaker and amp together.
AS soon as it stops raining outside i will try to figure out if its the dust cap or the speaker/amp.
Quick Reply: BOSE speakers for$40?!
