Boost-How high?
Boost-How high?
Hey, I got a 1999 a4 1.8t pretty much stock expect for a drilled airbox, 710N, and boost gauge. The car does have over 150k on it. Boost is around 5 psi.
With an APR chip it holds around 8 psi. Car does not have any check engine light. I have read other posts claiming that they are getting 8 psi stock and 15 psi chipped. I am definitely not even getting over 10 psi. I have checked to see if I was in limp mode but am not. Could my turbo getting old...Any suggestions?
lots of leaks!!! did a smoke test and smoke was pissing out one of the check valves completely rotted on underside near airbox...plugged that hole and then also smoke coming out of oil cap and dipstick. will try to replace next week
