boost gauge fitting
This ^ is a very common location. Just get a vacuum T-fitting from a local auto parts store (they usually come in a pack) and use one that's 1/8" or 3/16".
There is a check valve on the line going to the brake master cylinder, and this check valve has a port sticking out the side that was capped off on my car. At one point that cap was slightly damaged and was causing a boost leak so now my boost gauge line is connected to that little port, and a straight silicone line connects the FPR to intake manifold.
right by the coolant resevior are those black...diverters? in the vac lines. i was playing with them and actually you can cut the end off the "t" of it to get vaccum. VERY clean and its slick lookin. Dont have a digi camera lol otherwise ide show ya.
s4me
05-18-2005 08:39 PM
