Blown turbo question?
Old 07-12-2010, 05:37 PM
shhmaudi's Avatar
I am seriously stumped..
what did you try using that didnt work for you?
Old 07-12-2010, 06:58 PM
FASTER's Avatar
Tech Slut
Cut the head off, or drill it out, tap the hole, call it a day.
Old 07-12-2010, 07:01 PM
CCA4's Avatar
Sorry, I guess I was kind of vague in my last post. The problem is not with the design or function of the bolt remover thingy, just just that there wasn't enough exposed bolt head to allow the extractor to work properly. The tooth inside the one i used tapered from larger right at the rim of the socket, to smaller near the base. This allows you to use them on multiple sizes of bolt heads without having an extractor for every single possible size bolt. The carrier bolts were too big for the smallest extractor, but too small for the second-smallest because of the shallow bolt heads. I rambled a little, but does that make any more sense?
PhillipSnider
07-06-2013 06:38 PM
anythingbutordinary
07-07-2012 02:24 PM
smokem
11-23-2008 11:53 AM
DSMKiller
09-02-2008 05:56 PM
TopGUn86
01-17-2008 07:39 PM
Quick Reply: Blown turbo question?
