Blown turbo question?
Help!!!
Whats up fellas?
So today was a test of my patience. I got all the bolts to my oil pan out except this one. its stripped... Even the ones in the bellhousing that I had to drop the subframe for........
How would you guys go about removing this hex screw?
Its kinda deep. like maybe 10in from the screw to the end of the pan..
please help I neeeed to get this off..
Umm they need to come out, there is a plastic shroud in between the oil pan and the crankshaft, but a ball bearing could definitly find its way past that. They are telling you that the ball bearings came out and traveled down your oil return? What turbo are you running? Ive never heard of such a thing lol. Id check to see if they are lodged in the oil return line still. If they had gotten up into the guts of the engine, id think you would know it by now.
As for that last bolt, work on it with some vice grips and maybe a torch, be careful tho. clean the area first.
have you tried using one of those sharp bolt remover things? something like this.
http://0.tqn.com/d/homerepair/1/0/V/..._extractor.jpg
all it did was strip it out more.. so I tried drilling and no dice.. im so frustrated..its rounded on the outside.. Does that thing bite into it as you turn?
