Blown Turbo or Coil Pack?
Got my 01 a4 1.8t Quattro APR chipped today with the 91 octane setting. I was boosting fine all day today and came back, replaced my front struts and took it out to test them around.
For some reason though, i hit about 16 psi and my engine started sputtering.. then after that, I couldnt boost 4psi without my engine sputtering. Then i couldnt boost at all without sputter.. It seemed to work fine on vacuum and cruising around not boosting.. then as soon as i got home, it had trouble idling. kept dipping bellow 1k RPM and back. The check engine light kept bouncing on and off seemingly then never came back on...
I hope its not a blown turbo and maybe just misfiring with a coil pack and rough idle. Ive already replaced 2 and my car has 130k miles.
Any ideas?
Any ideas?
I have the R1 DV installed already. I'm pretty sure the bearings on my turbo are going bad, hear a clicking noise with high boost. Probably in need of a rebuild kit or new ko3.
On the other hand I'll run the codes in the morning and replace the coils. I just think it's weird it would happen within 100 miles of when I chipped. My last guess would be boost leaks.
^This. Re-gap your plugs and take it for a spin. None of the symptoms you listed describe a blown turbo.
Usually when your turbo goes it makes a loud dentist drill noise.
