blown motor need help
i have 2000 b5 with a blown motor i found another motor but the car that it is from had a automatic transmission i have a manual transmission. will the engine match up with my transmission? or will i need an adapter? or is it not even possible?
You should seriously paypal me 10 bucks for the amount of time I just spent looking for this but anyway, here is a quote from Mike that gives the best info. If you're still confused I would pm him.
Here is Chris's DIY, this was done on his 2001 A4 1.8t which has a 06A block while you have a 058 block. So there might be a slight diffence in the crank flanges.
http://www.audizine.com/forum/showth...ual-Conversion
Picture of the bearing he used as a pilot bearing. I have another customer that lives here in socal that did the tip to manual swap on her B5.5 Passat 1.8t. She too used the same bearing and also went with a CM clutch/flywheel kit.
Info for the bearing
-$19 Pilot Bearing from www.zorkos.com PN#A-6941
If I had the specs for the bearing I could most likely get it right from Clutch Masters.
