Belly pan hardware
Belly pan hardware
http://www.ecstuning.com/stage/edpd/...bcategory=Body
any help would be appreciated.... which set do i need to get? I would love it if all I had to get was the $14 or $20 set... but then they have the set with both of those combined... can I get away with the smaller sets?
the discription says, the plastic ones -This is the pin & clip set that attached fender liners to the belly pin. Kit contains the following:
4 t-bolt fasteners
4 clips that clip into the belly pan
the metal one says - This is the screw & clip set that attached belly pan to the sub frame Kit contains the following:
4 Metal quick screws with washers
4 metal clips that clip into the belly pan
you kinda need both if you want to use your belly pan, i havnt used mine since i got the car. over 3 years now.
4 t-bolt fasteners
well i don't have much storage area in my new apartment and i am tired of carrying it around with me... might as well use it if its in my car already
so would it be possible to just use one or the other... trying to be cheap hah
