Been gone for a while pics for clicks
hey guys i have been gone for a while real busy with work and school
if you read all this there is photos down at the bottom i need your help
but are the "few" problems
i have some codes dont remember right now and i deleted them off vag com stupid move
i do remember what they said i think :
system 1 bank too lean
abs mod malfunction ----- know what that is
o2 senor insufficient
and the new one of the day p0442 evap system small leak
and all say intermittent after them
so what should i look for i have searched nothing has really given me any good answers
i have checked the maf unplugged car dies , the purge valve work can hear it clicking away
my fuel injectors are loud never really thought about it but they tick alot dont know if normal or not
sounds like i have a blow off valve when i rev to 3200 rpms or shift there
holding down brake pedal and then letting off makes a hissing noise (only sometimes like once every 3 weeks )
you really have been MIA for ever
system 1 bank too lean (dont worry about this unless you get it again)
o2 senor insufficient ( most likely because you have exhaust now)
and the new one of the day p0442 evap system small leak (pull the plastic's covers off and look for any hosing thats damage or loose)
As far as the weird blow off noise, mine started doing it intermittently and eventually did it every time I let off the gas - for me, it was my DV. The rubber diaphragm in the stock one was almost completely shredded when I took a look at it after putting my new one on.
