Beat TB w/hammer & lost 5 codes wtf!??!?
Old 04-26-2008 | 03:27 AM
onepoint8tee's Avatar
Default RE: Beat TB w/hammer & lost 5 codes wtf!??!?
ORIGINAL: david9999
Throttle body adjustment is only on those cars who don't have a throttle cable (ie the TB is controlled electronically).
Wrong
This is the vag com/ross-tech's way
and the key trick shouldwork too, DBW or not.
Throttle Body Adaptation:
Turn the key on but do not start the car.
[Select]
[01 - Engine]
[Measuring Blocks - 08]
Enter Group 060(may be Group 098 on some cable-throttle cars)
[Go!]
[Switch to basic settings]
Once you do this you will see the top right display say ADP RUN. The TB
adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in basic mode for about 30 seconds, then switch back to normal settings and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
Old 04-26-2008 | 10:16 AM
chaos92287's Avatar
holy crap, onepoint8tee is back from the grave
audilover
02-05-2008 11:15 PM
04a4
12-14-2007 12:41 PM
dscott
06-12-2007 06:22 PM
sanjeevh
12-10-2006 12:51 AM
bbkid43
09-22-2006 01:45 AM
