Balanced Driveshafts?
Typically they mean driveshaft as in the one that runs the length of the car - it needs to be balanced so that you don't get vibration while the car runs. This is mainly on two-piece shafts connected by a carrier bearing/u-joint like our cars have. They aren't talking about the CV shafts/axle shafts. Most drivetrain/transmission shops can either balance a driveshaft for you or tell you who nearby can do so.
Did you buy a new one or are you trying to re-balance the one on your car already? I went through a couple drive shafts on my Bronco and they all came balanced from the supplier, seems odd that you'd have to worry about balancing it yourself
If its balanced before you take it out, then it will be balanced when you put it back in...provided you dont drop kick c*nt punt it across the garage into a flaming fire pit fueled with gasoline and dried up christmas trees
donistook
03-14-2007 08:09 PM
