Bad trade
Bad trade
Yesterday I traded a 98 blazer for a 2000 a4 Quattro. My blazer wasn't perfect and neither is the Audi--however I got shafted. The a4 drove fine around town but I had to pull over on highway on way home due to overheated engine. The interior is rough but I can replace all of that.
What is typical engine issues with these? I've owned German before but never an Audi (got it for the Quattro to keep my 135i garaged over winter-needed gas mileage better than blazer too) how does turbo hold up? Where should I look for boost leaks? Typical oil issues? How does engine internals hold up over high mileage? Any tranny issues?
It's got quite a few on the clock (160k) but for the year that's actually not bad. Auto tranny with slap shift, I'm tempted to just toss a whole new motor in but not sure I need to do anything that drastic just yet
I'm a mechanical engineer by profession and have the means and capability to do just about everything in my garage so no issues there
Throwing a whole new engine in is a bit excessive, it could be any number of things (water pump is most likely), did the car come with any service records? If not I would check the timing belt since its probably due for a changing, as far as the mileage, I have 195k on mine with original turbo and no major problems. Can you check and see if the oil is conventional or synthetic? That would make a huge difference in life of the turbo and engine itself
full synthetic oil
i was going to have dealer do a full inspection before i did anything--I was just seeing if there were things that I should have them look at specifically. There's quite a few electrical issues (speedo doesn't work, no windows or sunroof fiunctionality, key FOB is worthless, check engine light is on, oil light dings despite dipstick reading full, etc) so I want to do a scan of things and get a list printed out and start going through and fixing things before snow flies
The oil light is for low oil pressure which would definitely make the engine knock...and die. If the previous owner drove it hard or alot with low oil pressure the engine is done. You most likely have a sludge problem
I'm going to fix this car and make it good, lesson learned but you can't really help it when you are flat out lied to about the vehicle
yea that's what I was afraid of. I need it scoped and to find out for sure but after what i've been reading I'm going to start searching for a new engine and just start from scratch. i have a few months before i need it for winter so i can afford to tear into it
