B5 -98 2.6 quattro can't fit 18" wheels
![Default](https://www.audiforums.com/forum/images/icons/icon1.gif)
example. stock 205/55/16
205 = tire width in mm
55 = sidewall aspect ratio
16 = wheel height in inches
sidewall height = tire width * aspect ratio = 205 * .55 = 112.75mm = ~4.4 inches
tire height = wheel height + 2*sidewall height = 16 + 4.4 + 4.4 = 24.8"
op, it'll help if you give the width and offset of the wheels. a lot of people on here run oversized tires (I don't know why..) and you should be alright with just spacers since you're at stock height
Ok it will be off on the speedo but WHY wont it fit?! I run 225/40-18's which = 25.1" now I want to pick up for the track maybe a 17x9 or 17x10 now I know ET matters but according to the whole 25" rule I should be fine with 275/35-17 = 24.6" or cutting close with a 265/40-17 = 25.3"
UPDATE
So wheels ET= 35
Luckily i noticed 2 of the tires are 225 for the front so i will be needing spacers only in the back but could use some advice on how wide spacers
Here's a picture demonstrating the problem quite well, chassis is touching the tire just and just at the very edge
So wheels ET= 35
![](https://img263.imageshack.us/img263/1360/tiresr.jpg)
#18
Same issue I had with 235-35-19 tires combined with my wheel offset. Spacers fixed it. Don, most likely if a 25" height is the max that will fit, I bet if you measure from the center of the axle bolt out to the body, somewhere on that arch you'll find a distance of just over 12.5" (half of 25"). That means a radius of 12.5" (corresponding to a rolling diameter of 25") will be the largest that will fit.
#19
The pressure under the contact patch is affected by the width of the tire. Narrower tires are beneficial in winter conditions because the tire has less snow to push; the smaller contact patch also works to compact the snow more effectively than a wider tire would.
ESH
05-05-2012 12:11 PM
Trickflowing
06-22-2009 09:54 AM
raceze
02-18-2009 05:34 PM
NoobJuice
11-22-2008 06:12 AM
corvetteauto
09-02-2008 07:44 PM
