B&M short throw shifter install instructions
Old 06-14-2012, 02:38 AM
burgurboy's Avatar
Default B&M short throw shifter install instructions
Hey guys. I have a 2000 a4 2.8 Without push-down reverse.
Please, Before you kick down the door with the imminent "Use google you moron" comments, check out my entire post
I purchased an ebay SS and I'm looking for the infamous B&M install instructions. I have searched all over but, all of the links to PDF scans are broken. (thanks a lot megaupload, rapidshare, etc.)
Ive seen the videos for the JHM shifter and the stratmosphere instructions on audiworld but, they're not quite the same.
Does anyone have a copy or link to the B&M instructions?
Thanks!
Old 06-14-2012, 08:48 AM
CCA4's Avatar
I have a paper copy of them laying around someplace, but odds are that won't help you. I can't seem to find any of the links online either. If I can dig up the paper copy I have, I'll scan it for ya.
Old 06-14-2012, 11:08 AM
burgurboy's Avatar
That would be amazing...
It looks like there are several "types" of eBay shifters. Mine doesn't match up with the stratmosphere or jhm so... I THINK that just leaves the b&m...
My email is burgurboy at gmail, if you find them
Thanks!
Old 06-14-2012, 11:56 AM
cnigro1279's Avatar
Thanks![/QUOTE]
I know I have the .PDF for the B&M kit on my work PC. Worked good for my eBay kit. I'll email it to you tomorrow as I'm hanging at Foxwoods with the wife
Old 06-14-2012, 04:58 PM
85vert's Avatar
Just installed the ebay ss kit in my '98 b5 last night. Search all over for the B&M instructions with no luck. Had an idea of how to install by looking at instructions from other ss kits.
Since I have a pre-facelift model it would have required removal of the center console. Didn't have much time so did it w/o removing, which I was then only able to replace the shifter itself. I'll replace the bushings another time.
Wasn't sure of the ss setting so used the middle hole. The B&M instructions would have been nice to have and I would still be interested in a copy for future reference if anybody has one to share.
Definitely made a huge difference from stock and very happy with it. Also like using reverse w/o having to push down on stick.
Good luck on the install
Old 06-14-2012, 09:34 PM
Cybersombosis's Avatar
Check your email.
Doug
Old 06-15-2012, 08:49 AM
burgurboy's Avatar
Awesome. Thanks for yhr holp guys. I installed the shifter last night. It works great! I set it on the bottom hole. According to the instructions, this reduces shift movement by %33.
Thanks for the help guys.
Old 07-11-2012, 12:28 AM
FrostByte's Avatar
Originally Posted by Cybersombosis
Check your email.
Doug
Would you mind sending me an email with it also?
Sent you a PM.
thanks
Old 07-11-2012, 01:04 PM
bshusted's Avatar
I've got the pdf if you still need it.
Old 07-12-2012, 12:28 PM
FrostByte's Avatar
I am good. Doug got it to me.
Man, I guess with a 6speed, you don't use the metal ball you reuse the plastic that came with the stock shifter. It was a lifesaver for me.
Quick Reply: B&M short throw shifter install instructions
