AWM cyl 1 mis coil wiring harness
So i finally brought a scanner , genuine audi coil packs and spark plugs, cleared all the codes and still cylinder 1 misfire....i took a look at the coil pack wiring harness and i noticed cylnder 1 wires are cracked the **** up ouch, im pretty sure some of u awm guys ran into this same problem, i've done a bit of research and see that they only sell the harness for the vw 1.8t ... In the condition my wiring harness is in i feel if i touch it it will crack in my hands lol, so i dont realklly want to just cut out the wire and solder back to the connecter the whole harness must go, if i chose to buy the vw wiring harness how would i have to fabricate it to make it compatible with my AWM harness?
far from plug and play.
http://www.ecstuning.com/Volkswagen-...trical/ES7679/ there is the link to the ecs harness. it involes a lot of wires to splice. and confusing. otherwise the easiest way would be the vwvortex harness, cost a lot more. but a lot easier.
http://forums.motivemag.com/showthread.php?4502394
there is the vortex link
Huntersirg
01-08-2012 07:01 PM
Papa_Dios
09-06-2011 01:38 AM
volari554
07-13-2006 10:57 AM
