Aux fan wiring schematic needed !
My aux fan works when I give it direct 12v, but it never goes on by itself... which makes my AC semi-cold when i'm not moving.
What is the gross wiring schematic/what could be wrong ?
I thought it could maybe be the thermo switch
My issue was a fuse, orange 40 amp, that I needed to change and my aux fan worked then. The shop I called said there was no fuse, they wanted $500 to replace the fan.
On my A6 the fuse was located behind a panel beneath the steering wheel , remove two bolts, drop the panel.
