Auto Shifter knob (tip mod)
Old 04-15-2008 | 05:16 PM
jago's Avatar
Default Auto Shifter **** (tip mod)
ok here is a short/bad DIY i found looking online you will need to buy a spp (spreme power parts)( im sure you can find others but this is what i found firstish)tip mod for around 60.00$ you can go to supremepowerparts.com and look under audi/transmission then look for the "tip mod" and then a new shifter from 30-100.00$ depending on what look you want. Here is short image i found that describes the DIY. I will get my tip mod tomorrow along with the short momo shifter so after i install it myself i can post a litle more info....also i would like to think that some sort of instructions will come with the tip mod kit...
Removing and installing selector lever handle
Removing:
Move selector lever to "3" position.
Slide sleeve -1- down as far as it will go.
Pull button -2- out of selector lever handle -3- until it clicks (distance -a-) and pull handle upward.
Dimension -a- = 3 mm (1/8 inch)
Installing:
Carefully pull button -2- out of selector lever handle -3- to position indicated by distance -a-.
Then, with button -2- pointing toward front of vehicle, install handle -3- on selector lever and push down as far as possible.
Turn handle -3- until button -2- points toward driver's seat. The handle will engage in a vertical groove on the selector lever.
Push handle -3- down fully so it engages in circular groove on selector lever.
Press button -2- into selector lever handle -3-.
Pull up sleeve -1- until it engages in handle -3-.
Old 04-15-2008 | 05:37 PM
A4 Effort's Avatar
Default RE: Auto Shifter **** (tip mod)
Thanks for posting this. I always wondered how to get that damn **** off.
Old 04-16-2008 | 08:33 PM
powersmokin's Avatar
the shifter **** will come of in any gear position just as long as you pull out on the button.
Old 04-17-2008 | 12:31 PM
jago's Avatar
that it will its just how the diy put it....spp priority shipping sucks ***** i should have got this "Kit" Yesterday but nooooo..bast.ards
Old 04-18-2008 | 04:03 PM
brrman's Avatar
The stock **** sometimes is a bitch to get off. Mine seemed like it was glued on there - had to pull like a ****.
But it's a mod I would do again, thats for sure.
Old 04-18-2008 | 04:40 PM
hedman09's Avatar
Is there still a button you need push to shift?
Old 04-18-2008 | 06:10 PM
CAB509's Avatar
6th Gear
ORIGINAL: brrman
man where have you been???
Old 04-19-2008 | 09:23 PM
samleong's Avatar
ORIGINAL: hedman09
I want to know too. Anyone answer?
Old 04-19-2008 | 09:42 PM
mr.cAp's Avatar
I imagian you push down on the ****
Old 04-19-2008 | 09:47 PM
samleong's Avatar
how the tip mod works? how to install the tip mod??
the instruction only shows how to install the shifter ****....
im really interesting. can someone answer??
Quick Reply: Auto Shifter knob (tip mod)
