audio sound system problem
Old 10-07-2009, 07:34 AM
Andrew149's Avatar
i also had to redo my whole system i went with all polk speakers
Old 10-07-2009, 08:10 AM
b5blazing's Avatar
amps in the trunk left side mounted up top below speaker. and they started in 98' wit the amps
and the problem with the amp only running on am fm is a behind head unit missed wire connection that **** had me mad for 2 weeks in july
you can run an afterMARKET HU OFF THE BOSE but you have to hard wire it and sucks. yes even with the 600w amp you can.
and if you good you can retain the use of all 8 speakers. for awhile i was runnining oe amp and speakers with a 2400w leg and two 12' clifs till one day the oe bose caught fire in my trunk
Old 10-07-2009, 09:22 AM
dragonrage's Avatar
NO NO NO NO
guys
he hooked the amp remote to the power antenna wire, not the power amp remote wire from the HU. You need the white/blue wire, not the blue wire from the HU! The blue wire is for a power antenna and in many HUs will indeed come on only with the radio tuner since you don't need an antenna for CD playing.
Old 10-07-2009, 09:49 AM
ImTheDevil's Avatar
^^^^exactly. I was reading through to post this if someone didn't. On a HU with only one blue wire you tap into it. If you have two, you have to get the right one. The power antenna wire only gets power when the radio is on which as dragonrage said, is why the amp only works on am/fm.
Old 10-07-2009, 02:05 PM
1.8TNYC's Avatar
Originally Posted by dragonrage
NO NO NO NO
guys
the blue wire on the the sony radio is marked for remote
and the baby blue with with white is marked antenna
my remote is on the blue cable
Old 10-07-2009, 02:14 PM
dragonrage's Avatar
Try them the other way around because you've obviously got a power antenna signal, unless your HU has settings that control with what inputs the remote wire will be active. Worth a shot, no?
Old 10-07-2009, 02:20 PM
1.8TNYC's Avatar
will check when i get home
TITAN1981
02-23-2010 12:40 PM
paradisnuts
12-11-2007 01:50 PM
budfrog130
06-27-2006 07:11 PM
Covz
03-22-2005 08:09 PM
spearhead
01-12-2005 04:34 PM
Quick Reply: audio sound system problem
