Audina's oil change
Audina's oil change
Hey fellas, its been a few months, since I've logged into audiforums
Its about that time, to give Audina a oil change. She has 173,000 miles on her and still running strong, without a hint of oil sludge, due to being feed a steady diet of, synthetic oil.
I need a suggestion on which high mileage, grade and brand to feed, Audina.
My mechanic, also has, MANN filters and said he will install one in Audina and for me to buy the synthetic oil, i prefer.
So my question to you fellas are, what grade( weight ),what brand ( Mobile 1 ) and is the MANN filter fine for Audina? I currently have a Mobile 1 Filter, installed.
The summer is hot but its already august and summer is almost over,should i go with a different weight,being the summer is almost done or should i just keep a grade, that works best in hot temps?
P.S. for those of you, who have never met, Audina. She is a 2001 A4 B5 AWM 4 cylinder with high mileage.
I went with a MANN filter, from what i read everyone loves them, not sure why but its a massive filter compared to the napa one that was on it. I also used mobil 1 5w-30 full synthetic because of the price (26$ for the big 5 quart jug at walmart), i couldn't find a better price anywhere else. What i did before my oil change was seafoam the engine and after that the oil came out pitch black so it cleaned it out a bit. Maybe you should look into that, it could really benefit you.
Alright fellas, i'll take a drive to wally world and see if they have the big 5 quart jug of 5w-30 for $26.00.
I always heard about, using high mileage oil in older cars, hence the reason i asked.
I also have a very small oil leak( oil never drips to the ground, oil is only seen on the belly pan ) and need to get my engine, power washed or steam washed, from the top to bottom, so my mechanic can find, where the oil leak is coming from, anyone know of a shop in the tri-state area? CT/NY/ ? I can't find one place, that does this locally.
sollyd25
06-27-2008 01:52 AM
