Audi a4 B5 radio install
Old 05-29-2011, 03:11 PM
Audisaurus's Avatar
Originally Posted by MetalMan
I wired my entire audio system (4 speakers + sub, all with separate amplifiers), here's what I did:
-all signal and speaker wires are under the trim pieces on passenger side
-power wires under the trim on driver side
-speaker wires to the front speakers were run through the existing wire port. It's not difficult.
-amplifiers are mounted under the rear deck inside the trunk. They don't really take away from usable trunk space.
Removing the trim isn't bad at all. I've pulled mine up many times. There is a DIY somewhere for removing it, and I'm trying to find the link.
Personally I wouldn't trust the stock rear amp. It's TINY. Maybe good for 5-10watts RMS as a guess. Since your speakers are rated up to 55watts RMS that amp would not be doing them justice.
You mean u have a separates amp for the speakers and sub, i hope each speaker doesn't have its own amp lol
Old 05-29-2011, 06:06 PM
MetalMan's Avatar
Moderator
Of course! 4-channel amp for speakers, 2-channel bridged amp for the sub.
Old 05-29-2011, 06:49 PM
Audisaurus's Avatar
just making sure
Old 06-03-2011, 02:38 AM
rawdney88's Avatar
i ran into something similar to your problem. front speakers were replaced and were pretty much plug and play with the stock wiring. the new rear speakers however did not work with the stock wiring considering the driver's side rear had an odd wire connector plug from the amp (non-bose). i tried to mess around with it in an attempt to find the wire that would transfer audio from the headunit to the rear speaker but it was taking too long so...... what i did was wire both rear speakers individually to the headunit. needed an extra 12ft of wire but it works great. and of course 4 channel amp and 2 channel bridge for my 10" in the rear.
Old 06-03-2011, 07:51 AM
Audisaurus's Avatar
why do you all use bridges and not mono? i would never run a sub off anythign but a mono
Old 06-03-2011, 06:29 PM
twoeightquattro's Avatar
i have the same problem with mine. i put an alpine deck in, and the rear speakers don't work. i don't mind because i think it sounds a lot cleaner with bass coming from the back and then treble coming from the front. sounds more realistic and clear than to have treble and bass fighting eachother from the back.
Old 06-05-2011, 08:47 PM
Audisaurus's Avatar
or you can do the system right and have the treble and bass compliment each other and sound amazing
Trance08
02-17-2012 09:55 PM
cspaulding
09-18-2011 08:02 AM
TraineeV2
02-06-2008 02:16 PM
hypnotiks
09-30-2007 10:11 AM
converted
09-07-2007 04:52 AM
Quick Reply: Audi a4 B5 radio install
