Apr dv wont fit!!!
Apr dv wont fit!!!
My cousin just purchased the APR DV off their page for his 99 1.8T and now we discover that it does not fit the stock hoses... The vacumm hose to be more especific... Anyone encounter this problem or has some advice as to what i should do I would greatly appreciated it. I contancted APR and they said it should fit right in... But no luck. If its a easy fix by replacing the hose... I would just really want to know for sure from first hand experience...
Thanks in advance for good advice.
J
J
by vacuum hose you mean the small 1/4" one that goes to the top of the valve to the intake manifold? theres no reason that it shouldnt fit the stock diameter hose, but if it really doesnt just go buy $2 worth of vac line at autozone. if you meant the other two 1" main connections, it certainly does fit.
