Another headlight question
Old 11-25-2008, 01:53 PM
RyanSweeney's Avatar
What year model(s) of the S4 would I need to look for, in order to get a direct fit?
Old 11-25-2008, 02:22 PM
Jc61990's Avatar
the b5 00 - 02
Old 11-25-2008, 03:37 PM
SAudi's Avatar
you can reroute aftermarket fogs to the lower grille and tie them into the fog switch otherwise yes you loose the fogs.
Old 11-25-2008, 05:14 PM
ImTheDevil's Avatar
Yep to all of the above. The ones I have are listed asB5-generation RS4 lights, and they're two-piece so there is no fender trimming. You do lose the fogs, but I bought facelift fogs and installed them. The green/yellow wire in the headlight harness is the fog wire - simply use a wiretap to connect to it, and do as SAudi said - run the wire down to the facelift fog, connect it, and ground the other fog bulb terminal. The seller on eBay that I bought from was MakotoAutoTrends - look them up in the eBay community link and you can dig through their auctions or contact them about the RS4 projector lights for the B5 A4.
1.8tee
01-26-2008 11:51 AM
ant41487
09-12-2007 07:51 PM
kovalchuk71
03-08-2007 10:06 PM
BLRzAUDI
07-14-2006 07:36 AM
greenbeans
04-21-2005 11:09 PM
Quick Reply: Another headlight question
