ANOTHER brake light pad warning question
Hello all,
I just finished replacing my front brake rotors/pads because of the (O) in the dash. The (O) won't go away. GGRRRRRR!!!! (plenty of life left in the old pads and rotors too) DOUBLE GGRRRRRR!!! (wires fine. cleaned small amount of corrosion)
The ABS doesn't work either. (probably a bad module) Will that send any signals to the dash?
I have
"Brake Light" ... bad bulb ... (O) ... washer fluid
warnings flashing at me constantly and I'm trying to get rid of them.
Adding more washer fluid doesn't shut off that warning either.
The owners manual says a system failure will create a "Brake Light" to illuminate, but it doesn't say what system! Ideas?
I had a VAGCOM diagnosis done and I found I need a B1 P1 O2 sensor, No communication with ABS and The instrument panel has been replaced too.
ANY HELP GETTING RID OF THE WARNINGS WOULD BE GREATLY APPRECIATED!!!
THANKS!!!
gertron30
02-01-2010 07:34 PM
