Annoying wind whistle
ive been putting up with this noise as i thought it was a door seal around the frame that needed replacing but after a bit of investigation ive traced it to this plastic triangle as shown in the pic.
as soon as i go above 30mph the sound of whistling wind becomes noticably louder and also any speeds above 60mph i can feel the wind coming in if i put my hand in front of it.
it is a bit loose and if i give it a slight tug it moves away from the window, im not sure if theres a clip thats come loose behind this tiny plastic triangle or if a seal is missing.
can anyone let me know if theres a fix for this please?
open the door and check the rubber moulding i had this problem and the molding was just folded under. the little square pops of with a slight pull. then there is a foam block under it that sandwiches the connector for the mirror
