Alternator/Cooling Fan Removal . . PLEASE HELP !!!
I am trying to replace the alternator on my 2000 1.8TQ and its quiet the tight working space. I have to remove the cooling fan in order for the alternator and alternator mounting bolts to slide out in order to replace it. I can not for the life of me get the cooling fan off though, im using a spanner wrench to try and hold the idler pulley but where is the drive nut bolt to actually loosen and remove the fan???
Any suggestions or help is hugely appreciated!!! thank you!
http://www.audizine.com/forum/showthread.php?t=250650
there you go gl
for the skinny object to put through to hold the fan still a scratch awl works well
there you go gl
