alots of problems:need help
i cant drive it though it misfires sooo bad that it makes me want to like shoot myself, can you guys give em some good description on a coil pack going bad? maybe a personal example you know idk i need this car running asap
give me a step by step how to check it and ill go outside and do it right now. thanks
Unlike the 1.8, the coils on the 2.8l cannot be individually swapped, they are one unit. The best test you can do (even this is not 100% conclusive) is take a multimeter and measure the resistance between each coils output terminals, like in this pic. Resistance should be 8000 - 14000 Ohms
1996 - 1997 coil
1998+
To find out which cylinder is misfiring, start the engine. When it is running unplug the spark plug wire from each cylinder one by one and see if the engines behavior changes as you pull each one out (rpm should drop, engine should struggle a little). When you get to one that has little to no effect then you know you have a problem in that cylinder (could be caused by a bad coil, spark plug, or fuel injector).
1996 - 1997 coil
1998+
From reading multiple audi forums and also the passat forums (same 2.8L V6) it seems that the coils are a common failure and will result in a loss of power and a rough running engine. Keep in mind, if one coil is bad then you still have to get the whole coil pack.
Though rare, rough running engine can also be caused by a blown headgasket, bent valves, bad fuel injectors, etc.....
highly unlikely to be any of these? i got a feeling its the coil back
#19
i made it to the autozone parking lot.... car stalled and wouldnt start smelt burning plastic opened up my hood adn seen a cracked coil pack with plastic pouring out pretty sure its a bad coil lol
btu the thing is when i went to scan the ecu it came up as error. 3x soo im not sure wat the codes where previous code was a misfire on cylinder 6 and i dont think the ecu could receive a signal from the motor if the coil isnt sending a signal any input?
im gonna post up pics as well...thnx
