aledelic42's timeline.
#721
sorry. hopefully soon I'll have updates with bagged goodness
finished the turbo replacement today. I never want to do that again. the turbo is a lot louder and it spools up so quickly with the new piping.. almost too quickly. I'm afraid to try a wot, I put the pedal like 2/3 down and all the sudden it shot up to 26psi in 3rd gear at ~2.25 rpm...
I have no cel, no airbag light, no bad lights at all. it's weird.
Also (only reading from one page back) - were you running with a K04 without knowing it? That's also kind of strange, but awesome.
#722
lol yes I had no idea I was running a k04.. stock boost should spike around 8. I don't know how safe 26+psi is but no cel. the only things I have to boost higher are a giac tune and an n75j valve that I replaced when I thought my original one was bad. I don't know why I'm boosting so high though because it seems like most other people with tunes spike around 15-18
bethlehem pa? cool. have any pictures of your car? maybe we've seen each other around
#723
Haha, that's definitely strange.
Yeah, I'm living in the southside off summit street. Have been driving an RSX until very recently - the b5 was down for a timing belt job for a few weeks, but not it's a solid DD.
So far the car has been solid with the exception of a strange high-pitched whistling noise, which I think may be due to an exhaust leak.
#726
that sound could also be your turbo which may be gone. and aledelic caould ur boost be caused by you tune being for a k04 there for expectiong so much from the ko3 is forcing it? since you were running a ko4 your tune could be for a ko4 unless if you bought it for a ko3
#727
Makes sense about the K04 tune with a different turbo.. Sounds like you should get yourself another K04.
#728
#729
my tune is for a k03. I bought the car completely stock (besides the k04..)
walt I'm not sure what kind of whistling it is but you should check for a boost leak, that could be the problem
#730
...which may be attributed to a boost leak, as you say. They seem to be a bit harder to diagnose/detect than exhasust leaks. need an aircompresser and whatnot.
