Airbag check light -2001 audi A4 quarttro
RE: Airbag check light -2001 audi A4 quarttro
No you can't - battery disconnect will not clear an airbag light. You have to physically (via Vag) tell the computer that the airbag fault has been corrected.
Yap, that's the other issue Iam having, after disconnecting the battery connector the radio when into "SAFE" mode. This issue here is that I purchased the car used andthe sellersremoved the radio code card. Only discovered that now. I called the dealership and it would cost $110 just to retrive the radio code. Not sure if there is another way to get the radio code. Any ideas?
Thanks.
Thanks.
airbag ligh staying on
hi, i have the same problem, the light was coming and going for a while, then is stayed on, i cleared it one day with the launch x...diagnostic thing, but it came back few weeks later and now i cant clear is,, i took up the seat someone told me to bypass the yellow connector so i did soldered the 2 wires black to black and blue to blue , tried clearing it then but still would not, so do i have to get a new connector, why, its just a connector? or something else? would appreciate any help regards , j
#19
#20
Under quicklinks on the blue banner at the top of the audiforums webpage, go to edit signature and paste in the <img> code provided by photobucket or some similar sight you have a pic of your sig uploaded to.
