Ah... Camber question
I'm looking at my rear wheels and it looks like I have negative camber pretty bad. I have no suspension mods and I just had my wheels aligned. The tires I just pulled off were pretty chewed up on the inside. Two different shops did a visual suspension check and found no problems.. So they say
Any ideas??
Any ideas??
Do you have big wheels that could possibly be rubbing something? And if its on both wheels it's probably the toe not the camber. Camber would only be 1 wheel at a time. Did the shop just do a visual check or did they actually put it on a rack and give you some specs?
http://www.isham-research.co.uk/quat...alignment.html
you can check it by yourself by getting a tape measure and a friend, then measure the front of the back left tire (towards front of car) to the front of the back right tire, then do the same for the back of both tires. If the measurement is the same your toe should be fine, if not, get a REAL alignment done from a reputable shop
