after installing my cat delete test pipe i noticed....
Old 02-19-2011, 08:12 PM
Mr. Phil's Avatar
Question after installing my cat delete test pipe i noticed....
that instead of peaking at a sliver under 6lbs im now at a sliver under 7lbs... also everytime i let off the gas i swear it sounds like a blow off... is that supposed to happen? i mean its not loud and i can only hear it when no cars are around and my stereo is off... its a very faint sound... just wondering if anyone else noticed things like this after installing this...
the pipe i have is the 034 motorsports cat delete test pipe with new gaskets and bolts and also i have the o2 sensor extension for the post cat sensor which is why i have no cel popping up
Old 02-19-2011, 08:18 PM
chris120391's Avatar
Im not too sure about the sound but before i installed my 3inch test pipe i was spiking at 15lbs with the diode mod. and after i installed it i accidentally spiked to 22lbs. probably had somewhat of a clogged cat not allowing the turbo to breathe.
Old 02-19-2011, 08:31 PM
Mr. Phil's Avatar
well i cant do the diode mod unfortunately lol
Old 02-19-2011, 08:41 PM
Msnickbroderick's Avatar
Actual WIZARD
Cause you ghey
Your turbo is just breathing as it should now, so be happy! Any CELs, or did you use spacers
Old 02-19-2011, 08:42 PM
lol that just what i noticed because at first i couldnt turn it past 15psi. so you probably gained 1psi because your turbo could breathe better
Old 02-19-2011, 08:48 PM
Mr. Phil's Avatar
Originally Posted by Keegan0103
Cause you ghey
nope i got the o2 spacer... everything works like a charm... i did notice though when i first took it for a drive yesterday after everything was installed it smelled like something was burning... but i figure that was just whatever was on the pipe lol... no more smells as of today
Old 02-19-2011, 09:53 PM
turbo kraut's Avatar
Tech Guru
phil, you know us car knowing guys just call it a test pipe.... makes it easier to say... plus it doesn't let the non car guys know we are illegal.... not a knock just trying to help you stay out of a fine
Old 02-19-2011, 10:10 PM
Mr. Phil's Avatar
lol fair enough...
Old 02-20-2011, 12:48 AM
bradtyler02's Avatar
CHIP IT, and see what 15psi feels like
Old 02-20-2011, 01:17 AM
Mr. Phil's Avatar
like i said before... sending off my ecu is blegh lol... not having a car for about 3 days is gonna be poop lol
Quick Reply: after installing my cat delete test pipe i noticed....
