Ac high pressure side
Looks like you have to take it to a shop. No low pressure port on the 96. https://www.audiforums.com/forum/b5-...charge-106379/
You have to pull the low pressure switch off the line inside the cowl, next to the battery and get a special fitting to screw back on that you can connect to a gauge manifold set. There's a shrader valve under the low pressure switch so you can take it off without the refrigerant leaking out. You then have to jump the electrical connector attached to the low pressure switch so the compressor will run while your charging.
