AC blowing hot air!!! Please help
Ok I did a search and looked around but I can't necessarily find the answer to my problem.
Basically my AC does not work. It just got hot in Pittsburgh, and now I'm burning up.
From what I see here are the following symtoms
1. That Fan on the passenger side does not spin at all, whether the car is on or off and with the AC on full blast
2. My Low pressure is overcharged. Maybe I used those recharging kit too much but it is definatly over 150 PSI
3. Before this happened like last summer it will only blow cool air when the car was in motion.
4. It was working fine up until 2 weeks ago, when all of a sudden it stopped working and spewed out humid air
5. When it was working it was never really really cold.
5. My coolant temperature sensor is bad, but I didn't think it was an issue with the AC, but I could be wrong
6. When I switch the compressor on and off the engine revs a little, so I think the compressor is fine
Thats about it, anyones help would be much appreciated. Thanks
HeCareth
HeCareth
