ABS reprogram
Old 03-04-2011 | 09:51 PM
caliman's Avatar
Default ABS reprogram
so i have had the 18014 code since i have bought the car(month and a half) so today i bought a used abs module from a dismantler. installed it and still having the same code... dose this module need programing or did i get another jacked up module???
2000 a4 1.8tqm
VAG-COM Version: Release 409.1-S
Control Module Part Number: 4B0 906 018 P
Component and/or Version:
Software Coding: 07201
Work Shop Code: WSC 06335
1 Fault Found:
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-00 - -
Old 03-05-2011 | 06:02 PM
markymarc's Avatar
Been there, done that... IT NEEDS TO BE REPROGRAMMED....You're gonna need ALL the VAG COM numbers off the old module and reprogram them into the new one so it matches.... you're gonna need to put the old one back in and pull the numbers off of it with the vag com....then there are directions on how to do it here:
http://ebuild.elmark.net/media/ABS-replacement.pdf
Its for a VW, but same system.....which are awesome....good luck.
Marky
Old 03-05-2011 | 06:34 PM
caliman's Avatar
well with the old abs module i tried scaning it and my vagcom wouldnt connect to it... mabe i was doing it wrong?
Old 03-05-2011 | 06:46 PM
markymarc's Avatar
That's an issue, because you do need to find the codes for the old module somewhere, otherwise....you can't reprogram new one.....
Old 03-05-2011 | 07:30 PM
caliman's Avatar
just went to the car with the laptop and tried to scan the old abs unit and still cant connect to it. the only modules i can really scan is engine and instruments... so it looks like ill be calling the stealership monday :\
Old 03-05-2011 | 08:10 PM
morpheous's Avatar
do you have a registered version of the vag-com software? you should be able to scan the whole car and not just the engine and instrument modules.
Jestnomen
06-27-2015 04:44 PM
ozzy
04-28-2008 09:00 PM
carlv
04-26-2008 10:27 AM
auditt225
02-14-2007 03:19 PM
bigbird
06-30-2006 03:18 PM
