ABS Module
Old 02-26-2013, 09:58 PM
norcal89451's Avatar
Default ABS Module
u think if i just swap it out with a new one it will get rid of my ABS light and my "brake" light that blinks?
Old 02-26-2013, 10:10 PM
sbaer2's Avatar
you would be better off just sending old one out to get rebuilt. I believe its around $185 bucks and you can drive it around while they are fixing it. If you hear three beeps at start up then it most likely just needs to be rebuilt...you can save a lot of money this way..
thats what im doing next week actually
markymarc's Avatar
if your ABS light is solid and your brake light is flashing...the answer is yes....you can have it rebuilt...or find one in a junk yard...OR buy a new one...
If both lights are solid, it's more than likely a sensor.....
Old 02-26-2013, 10:21 PM
Alright thanks fellas.
Old 02-26-2013, 10:22 PM
cant i just sauder those 2 wires, ive seen in youtube vids, does that work and avoid not spending any money? lol
Old 02-26-2013, 10:27 PM
markymarc's Avatar
you can always try that 1st....and if it works, save $$$$$$
Old 02-26-2013, 10:29 PM
balla!@@ ha i am going to attempt, just did a turbo a week ago im sure i can do this... i already got it all out just gotta make the cut to get the plastic plate off then sauder! ty everybody for ur imputs & help.
Old 02-26-2013, 10:40 PM
zandrew's Avatar
My ABS light is on and has been on. My Brake light flashes as well. The thing that is weird though is that it has gone off on its own and will come back on after I restart the vehicle. Any idea on this?
I found the video. Why can you not just take the cap off instead of cutting it off?
Old 02-26-2013, 10:56 PM
jeckel20003's Avatar
I tried soldering mine. You need a very steady hand and some sort of magnification would be great too. It's tough.
Old 02-26-2013, 11:21 PM
markymarc's Avatar
The ABS light/fault resets itself when the ignition is turned off, then comes back on...all the codes will however stay in the memory...once fixed however, the light will go off, but, the old codes will be in there...but you should clear your codes....
Quick Reply: ABS Module
