ABS Light on. Brake Light Flashing sequence.
Old 09-04-2010 | 09:46 AM
rhessballin@gmail.com's Avatar
Exclamation ABS Light on. Brake Light Flashing sequence.
I have an Audi A4. 1999. The problem that i am having is here and there my ABS light comes on and so does my brake light. The ABS light is on and Brake light is flashing. Im thinking its a fuse, cause it happens on and off, I dont notice a difference of the perfrormance of the car when the lights are on or off, I need to figure out the solution. My dashboard has no other lights on so i want it to look clean, i cant stand when lights are blinking near your speedo. let me know. Could it be fuse or falty sensor. i dunno if anyone has any imput please let me know. thanks alot
Ric
check my garage for pics.
Old 09-04-2010 | 12:59 PM
Dallas09's Avatar
Search the forum, or look over page 1 and 2 on this forum. Sounds like a bad abs module, on its way out.
Old 09-04-2010 | 02:29 PM
Bertoli1.8T's Avatar
I am currently having the exact same problem heres the link to a thread I posted a couple days ago... might have something you can use!
https://www.audiforums.com/forum/sho...d.php?t=156164
Old 09-04-2010 | 03:18 PM
markymarc's Avatar
Dallas is correct. If your abs light is on and the BRAKE light is flashing...it's more than likely your abs module....not your sensors. If your ABS light and BRAKE lights are SOLID on, then it's a sensor or a speed ring....
Old 09-04-2010 | 07:01 PM
TeeterTawter's Avatar
abs module is faulty. get it rebuilt.
Old 09-04-2010 | 09:43 PM
chocalotstarfish's Avatar
Super Moderator
Since this kid posted here again I just wanted to say he is my idol! A quote from his facebook...
"Im a member at Audi Forums. best place ever. pretty much like Facebook but for Audi owners. so sick."
And the kid has an avant which I want so bad!
Old 09-05-2010 | 11:15 AM
thanks guys. Hopefully i can get this rebuilt A.S.A.P. What is the E.T.A of sending out a ABS modual and getting it back fixed correctly. Another question, Is it bad to run the car when this sequence is blinking. What are the cons for this situation? thanks alot. Shout out to all my fans out there. I know i am pretty much the cooliest thing ever. check my garage.
Old 09-05-2010 | 11:39 AM
Super Moderator
LOL I'm just a stalker and found you on fb...
Old 09-05-2010 | 01:13 PM
MetalMan's Avatar
Moderator
There's no problem to drive the car without ABS. I'm sure at least 20-30% of us currently are
Only downside is that you have blinking lights, and no anti-lock brakes. Your brakes still work just fine, but if you had to slam them on you would be risking locking up all four tires and going into a slide. Keep a little more distance between you and the car in front of you (especially if it's raining) and you'll be fine.
As for turn-around time on the module repair, most places will ship it back out to you within 2 days of receiving it.
Old 09-10-2010 | 10:42 AM
add me up on facebook.
zzr
11-09-2009 05:55 AM
blanthony
03-25-2006 01:18 PM
Quick Reply: ABS Light on. Brake Light Flashing sequence.
