ABS issue
ABS issue
Hey all, I bought a 98 Audi Quattro A4 with the 2.8 5 spd manual. When I bought the car the airbag and abs light was on and the brake light was flashing. So, I bought a Ross-tech setup and ran the codes. Needless to say, the airbag sensor was simple to take care of, I installed a deutsche connector and problem solved. As for the ABS, the left rear and right front were bad. So, I replaced the sensors. When monitoring the sensors (measure blocks) I get a signal with the left rear but still no signal with the new sensor in the right front. I checked the sensor for resistance and got around the 1340 Ohms (range should be 600-2400). So, I checked the abs connect that is on the car side (abs sensor connects to it) and got 13.6 milli-volts. I have nothing to go by what the reading should be here but that is why I am on here because this is something more than a simple RR process. Now, being a bit on the ****-side of things I felt that I would just go ahead and replace all sensors which I did. Again all work properly except the front right sensor which show no signal response.
I am open to suggestions as to what next? Below is the report for the code scan.
Thanks is advance for your suggestions.
Newtonhubcap
Newtonhubcap
