ABS and Ignitor ???
This is a pretty common thing, I'd suggest you search. Usually it's a simple matter of making sure the airbag connector under the seat is plugged together tightly. I wrapped a zip tie around the connector to keep it tight. Then you clear the airbag code and hope it doesn't come back.
