aaaand now my car wont start
Old 01-16-2009, 11:24 AM
superdooperme's Avatar
Originally Posted by Tweaked
Which flange actually cracked? The turbo flange or the cat flange? If it's the cat flange, leave the turbo alone and replace the cat with a Labree HFC or have a shop re-weld the flange.
well it wasnt the flange itself, it was the pipe right after the flange that goes directly to the cat. apparently theres a factory weld maybe an inch or so after the flange and thats where it seperated. ive heard the factory weld doesnt hold that well and the backpreassure can pop it apart.
but my shop WAS gunna weld it, but they called and said that the two pipes dont slide into one another, they just butt up against eachother and so i guess that means they cant weld it anymore. so their just gunna replace it.
but ya know... the cat probably needs to be replaced anyways, im at 125k
Old 01-16-2009, 11:31 AM
onepoint8tee's Avatar
Yeah sort of common for the cat flange to crack if not seperate completely. More than a few stories about that for sure. I don't think it has anything to do with back pressure though. Probably just that the cat is old and maybe a little clogged causing it to get too hot, then cool down. Enough cycles of that will cause anything to crack at its weakest point. Hopefuly you arent getting raped on this though. An oem cat is costly, and you can get it done for pretty cheap by getting a universal or labree, etc. cat/hfcat.
Old 01-16-2009, 11:34 AM
yeah... my shop said they found a replacement for 450 and labor is 150.
i dunno if thats rape or reasonable, but its gotta be done soon. ive got a driving day with my brother tomorrow against his 01 325i, haha
Old 01-16-2009, 11:36 AM
Thats rape.
http://www.labreemotorsports.com/products_vw.html
The labor seems reasonable enough though.
And if your state doesnt test emissions, ebay test pipes have proven to hold up for ~$100.
If saving $200+ on this isn't worth missing out on racing w/ your bro then go for it. Otherwise, you could do a ton better. What woule REALLY suck is to get that cat for $450, race your bro and lose, and then wonder if you could have won with a hfc or tp
Old 01-16-2009, 11:42 AM
I hate myself.
Old 01-16-2009, 11:46 AM
what is it a done deal?
Old 01-16-2009, 11:49 AM
yeah, it should be done this morning. im pickin it up after i get out of classes.
i dont mind it too much, the guy that owns it is a friend of my dads. he usually gives us a 30% discount, but we use him a lot. so i dont blame him for charging regular this time.
although maybe his quote wasnt including the discount yet. maybe that happens at the register.
  #18
Old 01-16-2009, 12:48 PM
$450 is steep if it's not oem. Ask him who supplied the part.
  #19
Old 01-16-2009, 05:37 PM
Tweaked's Avatar
Your cat didn't crack from back pressure. It cracked because it's old.
$450 is an after-market replacement or used OEM. OEM cat from a dealer is $750 + core charge. $450 is definitely either a terrible deal on a used cat or an OE style replacement OR it's a BANGIN' deal on a new OEM cat!
Labree is $250 + shipping and it's a high-flow and high quality. OE style replacements generally sell for about $300, but then again, the shop has to make some money on the part too. At least the labor they charged you was reasonable.
Dylan Cure
09-04-2012 04:21 AM
zslatcher
10-24-2011 06:15 AM
Billydakid
10-29-2010 02:40 AM
Quick Reply: aaaand now my car wont start
