A8 brake upgrade is on the car:)
#31
RE: A8 brake upgrade is on the car:)
This is polishing (pics are from my Z) - mirror-like finish that resembles chrome, only is far more durable since it's the metal itself, not a plating on the metal. It takes some time, more than paint does for sure, and it can be a pain to keep up, but it looks so good when it's shining.
Yeah, the torque wrench is exactly what you described. I had to get it because my existing one disappeared a couple years ago into the ether, and I have no idea what happened. I didn't want to risk warping the brake rotors with unequal/incorrect lug torque, or risk any of the other possible issues from that, so I just went ahead and got it, and yes it'll be needed for your clutch job (the impact wrenches will aid tremendously for that as well). Sounds good on the sealant - never hurts to at least have it on hand. Did you order it or get it at Empire?
#33
Heh, a lot. Clean it really well first off, and then it's a painstaking process of sanding with continually-finer grits (I usually start with 120 if it's not too rough a surface, but has texture - you have to get it smooth). If it's already smooth, I'll start with 220, then go to 400, then 800 to remove fine hairline scratches. After that I hit it with a couple grades of steel wool, and then a reinforced flannel wheel using Vernier's rouge, and finally a finishing step of White polish with a loose flannel wheel. There's some stuff called Zoop seal that you can use to seal in the luster and you usually don't have to repolish it at all for about three years, but it is hugely expensive (like $120/pint or some ridiculous number last time I looked). I'm probably going to just paint them and save the hassle of first doing the polishing, and second keeping it looking like it should when it's polished.
