A4 Turbo advice please help!
Hi people,
I have a 2000 B5 1.8t. I want to get more power from the turbo but not sure which is the better option. I can either fit a boost controller or put a bigger turbo on it. It is the 177bhp model and being a 1.8 just how far can I go without losing to much torque.
Also how high can I boost safely on the stock engine. I am also going to put a front mount on it too. Also I want to put some nice rims on it with some sticky rubber. I want to go to 18's, it is fitted with the sports suspension kit with 16's at the moment. Can I lower it anymore or do I not need to with the sports suspension as I want it sitting low on the rims without causing any scraping issues.
Any advice will help and thanks in advance.
RE: A4 Turbo advice please help!
You realy need to search as this more than documented on here but just to put you straight on a couple of things.
You have a 170bhp stock car but when mapped could yelp around 210-220bhp from a map and new DV.
There is a thread on here regarding using a a MBC and diode to up the boost, after that you are looking at Turbo's
Hey thanks for the reply good info cheers.. I done some more research and mine is 132kw, over here in New Zealand we work on kw rather than hp and 132kw = 177hp. It states 132kw on my spec card in the manual and this was comfirmed by the Audi dealer.
Thanks
Thanks
