A4 1.8t misfire only on acceleration
Old 04-26-2012 | 12:34 PM
stvoffutt's Avatar
Default A4 1.8t misfire only on acceleration
I have a 2001 Audi A4 1.8t with 116k miles on it. I recently had this same issue and read up on it back in September of 2011. I was receiving a check engine light and it read misfire. I don't remember what cylinders. Anyways I replaced the plugs and coil packs. I bought the coil packs from a local auto parts store as I don't live very close to an Audi dealer. It is now the end of April and I am encountering the same issue (misfire upon acceleration) but there is no check engine light. I have searched the forums and have only seen this issue accompanied with the CEL. What could this be? I am replacing the air filter today to see if this helps but I seriously doubt that this would cause the problem. Could the coil packs already be bad?
Old 04-26-2012 | 01:01 PM
ImTheDevil's Avatar
Yes they could be. You also could have a vacuum leak causing a problem.
Old 04-26-2012 | 02:25 PM
CCA4's Avatar
I've experience misfires with no CEL. Ended up being a (massive) vac leak. Do you have a boost gauge?
Old 04-26-2012 | 06:45 PM
stvoffutt's Avatar
No, I don't have a boost gauge. This happens only when I, for example, want to pass someone and I don't grab a lower gear to pass. Maybe it's a turbo issue?
Old 04-26-2012 | 07:11 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Doubtful. When one of my coil packs was bad it would only happen under acceleration.
Scan for codes, see which cylinder is misfiring and swap the coil pack around. If the misfire follows the coil pack, that coil is bad. If the misfire is random, it is most likely the ICM.
I put my money on the ICM.
Old 04-26-2012 | 07:32 PM
CCA4's Avatar
And get a boost gauge.
Old 04-26-2012 | 08:03 PM
Also that.
Russ Heinrichs
08-18-2021 01:39 PM
chanman45678
08-26-2013 03:45 PM
noir
07-30-2013 12:51 AM
dorkfish
05-06-2013 10:58 AM
