A4 1.8 turbo spark problem
change the hardware with another pistons and see if its a different piston thats now messed up. if its the same piston not firing then check to see if the piston is receiving fuel also. You might have a problem with your connector to the coil, or a bad wire on your harness, so check thoughs next.
