99 A4 2,4 Tiptronic problem
Old 11-21-2011 | 05:24 AM
kuven0107's Avatar
Default 99 A4 2,4 Tiptronic problem
Hi all.
I am new to this forum and require some assistance and/or advice.
I have a 99 A4 2,4 Tiptronic, and I seems to have a problem with the transmission/gearbox. It can select all the gears but only moved in Reverse. When you put it into Drive, or 2,3 or 4 and you press the accelerator it does not move.
What is the cause of this? or is the whole transmission/gearbox damaged?
Old 12-05-2011 | 12:41 AM
kuven0107's Avatar
I picked up these faults with VAGCOM cable..
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8D0 927 156 R
Component: AG5 01V 2.4l5V RdW 8518
Coding: 00000
Shop #: WSC 00000
VCID: 3C7330C304AB
5 Faults Found:
00300 - Transmission Fluid Temp. Sensor (G93)
30-00 - Open or Short to Plus
00268 - Solenoid Valve 6 (N93)
31-00 - Open or Short to Ground
00266 - Solenoid Valve 5 (N92)
00270 - Solenoid Valve 7 (N94)
00264 - Solenoid Valve 4 (N91)
Old 12-05-2011 | 08:34 AM
jonbonesjones's Avatar
Moderator
00300 - Ross-Tech Wiki
a sympton is tranny not shifting properly. Thats just for the fluid temp code. Idk about the other ones but I'm gonna guess they have something to do with the tranny control module?
Old 12-09-2011 | 06:40 AM
kuven0107's Avatar
Hey dude.. Thanx for the repsonce.. Was doing a bit of searching on google and seem that people have issues where the TCM gets water damaged... Need to check that also..
abiv95
05-20-2013 06:27 PM
Dadan
B7 Models
12-06-2011 05:30 PM
ramses
01-26-2009 12:31 PM
QuickQuattro
06-26-2007 08:56 PM
bAyArEaTQ
01-24-2007 10:25 PM
Quick Reply: 99 A4 2,4 Tiptronic problem
