98 A4 Quattro 1.8t Whatever?
first of all im pretty sure my car misfires whenever i am 50% throttle and it needs an ac belt and a new tire and a new cat as well as a handfull of other minor things...so i was really just looking for a good place to start. any suggestions?
Front bumper not being firmly secured in the corners is a common issue, clips gets broken/worn out.over time. Common issue.with mis fires is the coil pack, and spark plugs. Basic maintaince starts at looking for boost/vaccum leaks, checking the water pump and timing.belt, and obviously checking the air filter. Hopefully this points you too the right direction. Also dont forget to check your axles, bushings, and front suspension.
with this car i see most of the common problems that it is known for maybe not so bad as others have endured but in the long run i am looking to try and make this car moderately fast and sound good run and drive better.
