98 A4 2.8L cruise control issue
Old 01-04-2011 | 06:30 PM
yacoman89's Avatar
Default 98 A4 2.8L cruise control issue
I have a 98 2.8L manual transmission A4 and the cruise control will not work. The indicator on the dash does not show. I have checked all the fuses and also checked the cruise module box behind the glove box. If anyone knows what other parts I should check that would be greatly appreciated.
Old 01-04-2011 | 08:43 PM
MetalMan's Avatar
Moderator
I've got a whole slew of bookmarked sites on this cruise control issue, as mine hasn't been working at least since the previous owner had the car. So far I repaired the CC switch itself to no avail. Anyways...
http://forums.audiworld.com/showthread.php?p=1936114
http://search.audiworld.com/showthread.php?p=23807054
https://www.audiforums.com/forum/diy-do-yourself-55/write-up-b5-cruise-control-module-fix-57846/
https://www.audiforums.com/forum/sho...63&postcount=9 (references the link above this one)
http://www.passatworld.com/forums/sh...d.php?t=315443 (I'm guessing the Passat CC system should be similar to the A4 CC system)
Old 06-18-2014 | 01:08 AM
normal's Avatar
What do you mean by having already checked the module? If you haven't tried swapping in a known good/working unit, I would recommend doing so. You don't even need to remove existing module, just lower glove box, unplug existing and plug in new/different unit.
After much researching, worrying, and procrastinating i just did this on my 98 2.8 this week (with cheap used unit off ebay)... within 5-10 minutes of opening package from mail my cruise was working just fine.
Old 06-18-2014 | 09:50 AM
mtroxel's Avatar
Yea I'm not sure what "checked the module" means either. There are several points where that system can fail. I've had to sort through that on a B5 and on a C5. This write up takes you through the whole system rather than assuming the problem is in one spot. Very good.
Cruise Control Diagnostic for Non-DBW A4 Ver.1 (Longer than Long) - AudiWorld Forums
Old 06-18-2014 | 09:55 PM
turbo510's Avatar
I went through a bunch of trouble-shooting, some time after 2005 when I bought my '96 with a non-working cruise control. As mtroxel says, there are plenty of places where the system can break down. I powered the vacuum pump and solenoid dump valves throught the disconnected module's connector, checked for speed-signal, brake light switch signal, power and control signals from the stalk switch (which I also dissembled and cleaned). In the end, I bought a used module from a guy parting out an A6, and it's worked ever since. At the begining of year we bought a house about 45 freeway miles from my work, and I really appreciate having the cruise working.
I have since read that more than a few people have re-soldered the three red-colored capacitors on the module's circuit board, and had sucess.
yacoman89
01-04-2011 06:18 PM
bud8817
06-24-2009 06:38 PM
mat8980
04-08-2009 05:53 AM
Belligerenceā„¢
03-05-2007 06:24 AM
snogoer
10-27-2005 04:36 AM
