98 a4 2.8 vs. '06 mazda rx8
hey im just looking for some other opinions, i own a 1998 audi a4 2.8Q with a K&N intake and a Speedtuning chip and i was asked to race a stock 2006 mazda rx8...i could either pick a 1/4 mile race or 3/4 mile do you think i would have a chance of winning, and which distance doyou think the car would perform better in vs. the rx8
RE: 98 a4 2.8 vs. '06 mazda rx8
RX8[/align][/align]
[/align][/align]
•[/align]2,616 cc 2.6 liters rotary 2 front engine with 0 mm bore, 0 mm stroke, 10 compression ratio, none and zero valves per cylinder RENESIS[/align][/align][/align][/align]
•[/align]Power: 158 kW , 212 HP SAE @ 7,500 rpm; 159 ft lb , 216 Nm @ 5,500 rpm[/align][/align]
[/align][/align]
Audi:[/align][/align]
[/align][/align]
2,771 cc 2.8 liters 6 V front longitudinal engine with 82.5 mm bore, 86.4 mm stroke, 10.3 compression ratio, cast iron block, light alloy head, double overhead cam, variable valve timing/camshaft and five valves per cylinder
[/align]
-[/align]Power: 142 kW , 190 HP @ 6,000 rpm; 207 ft lb , 281 Nm @ 3,200 rpm[/align][/align][/align]
[/align][/align]
ORIGINAL: mhellman
I was under the impression that the A4 with the 2.8 would run closer to a 16 second 1/4 mile? (i.e. it's about as fast as my Odyssey minivan)
