97 a4 wont rev past 2500 rpm
97 a4 wont rev past 1500 rpm
Hi my Audi a4 wont rev past around 1500 rpm the shop I took it to told me it needed a new throttle body so I got a new one and replaced it myself the car is idling low and when I hit the gas the rpm go to 1500 then quick go back down to idle and if I hold the gas down it will just go up and down and sometimes stall if I rev the car with my hand from the throttle body as so as I start to rev I hear a faint sucking noise idk I think its prob just the intake but do you think it is a possible vacuum leak i just dont know what it would be and its running a little rough and low idle but if I bring up the rpms just a tiny bit it runs smooth at about 1000 rpms
Double check bolts on Tb.
Also try putting key in ignition and turning it to the on position ( don't start it though) the throttle body will buzz and click kinda thing. Now start the car.
Might need a throttle body adaptation
Where do I get a decent price on new TB and how do I do the adaption process after install?
I have this scan tool
Autel
and old throttle body removed.
Thx
98 A4 autotrans w/2.8l engine
TB ohm test is eratic or no movement at all
Code says no tb signal
Idles but will not take throttle pressure
Autel
Thx
