96 overheating
Old 12-16-2013, 02:56 PM
Kamil`'s Avatar
Blown headgaskets are more common with turbo engines than N/A correct?
  #72
Old 12-16-2013, 06:47 PM
rmr1499's Avatar
Ok did more testing unbolting stuff and it's not the resv the hearcore line has a hole leaking shooting at the resv and dripping on manifold that's why it looked like resv
  #73
Old 12-16-2013, 07:30 PM
mtroxel's Avatar
Nice. Now you're getting somewhere. It makes sense that you had more than one problem.
  #74
Old 12-17-2013, 12:45 PM
rmr1499's Avatar
Ok one more thing what ratio should coolant be or is strAight g13 fine
  #75
Old 12-17-2013, 12:46 PM
mtroxel's Avatar
50%/50% Straight actually has a higher feeze point.
  #76
Old 12-17-2013, 12:59 PM
rmr1499's Avatar
Ok thanks
  #77
Old 12-18-2013, 04:57 PM
rmr1499's Avatar
Ok I think we're finally good went on a drive and no issues we will see again In the morning on way to work
  #78
Old 12-18-2013, 05:04 PM
mtroxel's Avatar
Good thing.
  #79
Old 12-19-2013, 05:45 AM
rmr1499's Avatar
Ok so did some driving and alls good with cooling system so far. But every so often when I'm coming to a stop and pop the clutch in the car does out and when I re start it and so there the idle jumps from 8-900 rpm down to 100-200rpm and back up and down until I drive it till the next light then it will be good the. Randomly might do it again no set time just funky idle
  #80
Old 12-19-2013, 07:37 AM
mtroxel's Avatar
I've forgotten by now, but this is a 96 with the 12 valve V6 right? That has an idle control valve that can get clogged up. Here's a great DIY on how to clean it.
Kris' Audi Page :: Technical Articles
Quick Reply: 96 overheating
